Can Vg Disconect If It Detects I Have Picked Up The Line?
Hi, Can dialogic cards or VG detect someone (ME) has picked up the line? I am thinking not, but figured i would ask just in case. :)
I know I can select the line and then click the HANG UP button after I pick up the line, but was just wondering...
Or is there some way to force the call to forward dial out to another line? (like if i come to the computer and see that VG is taking a call, can i do anything that would interupt VG script and transfer the call to another line that i can then pick up and answer?
thanks in advance. : )
It's not possible to detect if some other handset attached to the same phone line is picked up.
But you could design a script in such a way that from every module it goes to a hangup module when a certain DTMF key is pressed. Then after you pick up a handset just press that key (say *) and VoiceGuide will detect that key and hangup, and then you will be able to speak with the caller uninterrupted.
